Grinding Noise when i let clutch out!!!
I just installed a new clutch, master, and slave, whenever i put the clutch pedal down i hear a load roar like gears. Is this a bad bearing, if so is it the TO bearing, and suggestions i appreciate it.
You got it back asswards letting the clutch out is engaing -is releasing the pedle Pushing the pedle is releasing the clutch. Noise with the pedle pressure is TO bearing or clutch set up.
