Need some help with a T/O
Old 04-07-2006, 08:27 AM
Shamson5.7's Avatar
Default Need some help with a T/O
Im looking to get the LS7clutch/LS2 flywheel package and I was wondering if there is a certain throw out bearing that I needed. Help would be appreciated.
Old 04-07-2006, 12:56 PM
jyeager's Avatar
Our cars don't have a TO bearing, they have a slave (it's just a hydraulic TO bearing). You use the same old LS1 slave. You could use the old one without the need to bleed the hydraulics, or you could replace it which is generally recommended because it is a wear item.
You might also want to get a pilot bearing while you are in there. They are only about $10. For this, you also get the LS1 part.
FYI, you also use the LS1 flywheel and pp bolts, so nothing new is needed there because of the swap either.
