Gap between TO bearing and clutch
This is for a C5 but should be applicable to any internal slave cylinder/clutch set-up. When the clutch is engaged, ie. pedal is not pressed in, should the throw out bearing be contacting the spring levers "fingers" on the clutch or should there be a gap? If so how much?
Thanks
Chris
Thanks
Chris
