Clicking noise when pushing in clutch?
I just got done installing my new Mcleod Adj. Master..... Its set up close to the 'Stock' setting, and whenever I press in the clutch it makes a single 'CLICK' when it gets close to the floor. I didnt even start up the car after the install... I was in the process of bleeding the clutch when I first heard the sound.. When you release the clutch, it clicks again....
Is this normal? It didnt happen with the stock master cylinder, so whatever it is, its coming from the Mcleod... Im just not sure if its suppose to make that sound or not.....
The system was bled using the Mity Vac method, and the clutch feels fine/solid.... I just dont want to start it up and take it for a spin until
I know its operating OK...
Thanks in advance!
Brian
Thanks in advance!
Brian
