vibration from tranny HELP
Its was not doing it before. I change my clucth,put a new spec stage 3 with pressure plate,pilot bearing and a slave clinder with throut bearing and reserface the flywheel, went for test drive and after like 2 rpm the car starts to vibreat i was thinking is because it wasn't break in, but it has around 2500 miles now and still does the same thing
torque down flywheel and pressure plate.
DO I NEED TO BUY A NEW FLYWHEEL?
