New clutch coming, a few questions??
I just ordered a centerforce clutch and flywheel for my car, with my old clutch sometimes the pedal would lay on the floor when launching or under heavy acceleration. What do i need to update on the hydraulics to help it perform better?? I dont think the clutch came with a new Throwout bearing and pilot bearing, should i order these also??
Originally Posted by seth webster
Will doing the drill mod to my stock LS1 slave cyl. keep my from haveing to buy a LS6 slave??
Originally Posted by toofast99
The drill mod only drills out the restriction in the steel braided line that connects the master to the slave. You would still need the 01+ slave.
Well thank you, do you know if i should goahead and get a master cyl also??
