450hp through a t56
Old 04-25-2006, 11:36 PM
XtremeDime's Avatar
Default 450hp through a t56
what will i need to do to a t56 to make it handle from 450-500 hp?
Old 04-26-2006, 02:00 AM
ChaseSS's Avatar
do you mean 450-500rwhp? or flywheel? You really could get away with leaving it how it is...its the rear end you would need to worry about before the T56
Old 04-26-2006, 02:05 AM
XtremeDime's Avatar
at the wheels. i dont need to upgrade to stage 2 or 3 clutch then?
deadmanTA's Avatar
I was always told that the t56 was good for 450 at the wheels
Old 04-26-2006, 02:09 AM
deadmanTA's Avatar
Yeah you need a good clutch with that. The stocker will go out by 400 rwhp
Old 04-26-2006, 02:15 AM
XtremeDime's Avatar
can u point me in teh direction of where i can pick one up?
Old 04-26-2006, 06:23 AM
Stang's Bane's Avatar
almost any one of the sponsors.
Old 04-26-2006, 07:29 AM
LS1Tech Sponsor
Slowhawk's Avatar
The tranny will last.We run 800hp/800tq on our's no problem. But you will need a clutch.
Old 04-26-2006, 07:30 AM
BBADWS6's Avatar
I was making 450 + EASY and mine was completely stock.. Just had a stg 3 spec clutch.
Old 04-26-2006, 10:36 AM
seth webster's Avatar
You can get a centerforce dual friction clutch with steel flywheel from BYUNSPEED for like $630 and that should hold that hp without a prob and you might want to think about uprgrading you master cyl and throwout bearing.
Old 04-26-2006, 12:15 PM
LS1powerhouse02's Avatar
i would look at the new centerforce 12" dual friction clutch. I have one and am very impressed with it. Just make sure you do get the 12" dual friction and not the old 11" design. As far as the tranny goes you will be just fine.
Old 04-26-2006, 01:47 PM
SMOKIN01TA's Avatar
id stay away from centerforce until we see some real drag racing and durability results out of these, the old style didnt hold up worth a crap, spec, ram and some of the proven names is what id look into, long as they are installed properly they will hold up well, my spec 4 lasted a LONG time and i beat the garbage out of it
Old 04-26-2006, 02:56 PM
XtremeDime's Avatar
thanks guys i will check em out. i was looking at the RAM just a couple minutes ago.
Old 04-26-2006, 04:51 PM
Viper's Avatar
RAM 980 lasted 10K miles for me, no drag racing just hard street shifting. They have made improvements however since 02'.
Quick Reply: 450hp through a t56
