air in lines?
air in lines?
I put my car on the lift raise the rear tires up of the ground put it in first gear, push the clutch in rev it up . anythig over 5k the rear tires start to spin....... do i have air in the line or is the spec 3 not enought for 480rwtq
i have the same issue. car jerks forward sometimes. i spoke with a textralia tech and he suggested it could be as simple as bleeding the system. but no with a mity vac. do it the old school way. 2 people. crack the valve, press down the clutch pedal, close the valve, release the pedal. repeat. just be sure to keep the resevoir topped off if u do it more than 3-5 times.
