killed rsp stage 3 clutch from carolina clutchs
Old 05-02-2006, 11:10 PM
bernard shortt's Avatar
Default killed rps stage 3 clutch from carolina clutchs
well killed clutch #2 now .mcleod street twin 6months ago and this past friday killed my stage 3 rps dual disc clutch from carolina clutch,
happened during a burn out ,for some reason my car kept dying while doing a burn out and wheni lauched the car smoke came from under the car and no gears so i guess the clutch is dead,i have ordered a new stage 4.5 clutch from rps that should hold 800 hp with the cynergey alumnium flywheel and 2900lb flex plate ,do u all think this clutch will hold my car????
Old 05-05-2006, 04:37 PM
white01ss's Avatar
Default How Much Power?
If you already killed a McLeod dual disk you must be pushing some serious power. How much power to the wheels are you making? Also, I wanted to clarify that the RPS stage 3 isn't dual disk, it's dual friction.
