Hurst ??'s
Old 05-18-2006, 05:39 PM
Camaro_Z28's Avatar
Default Hurst ??'s
Whats the difference between the aftermarket hurst shifter and the Factory one? Just curious, I was looking to buy one and was wondering if it would be OEM Quality. Thanks
Old 05-18-2006, 09:00 PM
Moderator
thechef's Avatar
i just swapped the factory hurst out for the aftermarket one and i LOVE the aftermarket Hurst
Old 05-19-2006, 11:18 AM
INMY01TA's Avatar
The aftermarket ones have stop bolts like a Pro 5.0 or Ripper I believe. Should be slightly better than the OEM one.
Old 05-19-2006, 12:06 PM
lt1formula2000's Avatar
the after market actually has a thick billet base that will prevent flexing and it has the adjustable stops. I would do a search the it seems to be a toss up around here as to whether the B&M or Pro 5.0 is the shifter. personally I have a hurst(aftermarket was on car when I got it) I have drove one with a B&M and it is as good or better than the hurst. I plan to buy a Pro 5.0 once I get my motor and rearend built like I want.
Quick Reply: Hurst ??'s
