adjustable master cylinder?
I am having problems shifting my car like i use to before i put the SPEC 2 clutch and upgraded slave cylinder in my car.
I thought that bleeding the clutch again might help but it didn't.
Do you guys think that the adjustable master cylinder would help my car, or have any of you guys had any luck with this problem....
thanks
thanks
Cheap adjustable master idea. I cut the master rod in half and used a die (spelling) I think it was 5/8's and threaded both ends and used an inch or so brass collar deal to connect them. Just loosen the collar to get more length and therefore more pressure in the master.
