Transmission Gear Grind
A few times this week when putting the car into first gear it will grind a bit. I know that my third when putting it in to fast it would grind. And from what i have heard its most likely my slave cylinder, since i have the Pre-01 cylinder. But i am in confusion on why in first it would grind the way it does, as if i am not pushing in the clutch all the way. Anybofy have any ideas, thanks by the way.
-Joel
-Joel
If its actually grinding, it could be a syncro.
As far as having trouble getting it into third, it might be air like the guy above said, it could be something the drill mod would take care of.
Yeah there are, times that the tranny gives a good shake as if i am almost putting it into gear without the clutch. Its ******* weird, i have no clue.
-Joel
-Joel
