Slave cylinder removal?
Old 07-21-2006, 02:31 PM
USMARINE1108's Avatar
Default Slave cylinder removal?
I'm installing a new trans, and putting on a new slave cylinder. How do I get the hyd line off of the old cylinder? Does anyone know of a good write up on how to bleed the system? Thanks.
Old 07-21-2006, 02:58 PM
BIG_MIKE2005's Avatar
you can either use a quick dis-connect tool or (2) flat head screwdrivers.
Old 07-21-2006, 09:49 PM
991LE's Avatar
Well, I copied the old original buschman clutch bleed and that is pretty much how I do it now even after all this time.
Buschman clutch bleed
