driven gear TSB?
driven gear TSB?
i found out from my co worker that the T56 and T5's have a TSB on the driven gear because it doesnt stop spinning after awhile with the transmission's life. if so, thats the cause of my grind problem when shifting gears on idle with the clutch in.
anyone know if that is true?
That sounds right. My Liberty T56 will clunck going into first gear when the car is still and the clutch is disengaged. If you want to stop the gears inside from spinning, just put it in any other gear first, then go into 1st gear.
Andrew
Andrew
yea im gonna have to rebuild the trans soon i guess to stop it from spinning permanently like how it was factory.
i get a clunk going into 1st at a stop and slowly rolling. and while backing out, then going to first while still rolling back slowly.
thanks for the advice.
