lightweight flywheels and heavy duty clutches
Old 10-07-2006, 12:37 AM
96ta's Avatar
Default lightweight flywheels and heavy duty clutches
i plan on getting a spec stage 3 clutch and i also wanted to get a lightweight aluminum flywheel but ive heard stories of people shattering the flywheel when using high clapping force clutches. do you guys think it would be safe to go with an aluminum flywheel with the spec clutch? have you heard stories of this yourself? Or perhaps do you think i should go with a billet steel flywheel? your help is appreciated
Old 10-07-2006, 12:51 AM
98camaroLS1M6's Avatar
No, you should be fine, unless you are 600rwhp plus or want to launch harder than a 1.40 60' you should have no issues. Fidanza aluminum FTW!
Old 10-07-2006, 03:42 AM
chicane's Avatar
Fidanza.....
Old 10-07-2006, 01:56 PM
96ta's Avatar
alrighty thanks
