LT1 Clutch install problems
So I am doin a M6 swap in my 94 Z28 and have ran into a kink... I think that when I installed the clutch I didnt have my throwout bearing turned correctly and now the fork doesnt seat all the way onto it... So when I put in the slave the fork pops off.... I managed to get it to stay once in hopes that when I turned the car over it would fix itself... but it just pops back off when you depress the clutch... I think the bearing not being angled right is what is causing my problem... anybody have any insight on this topic... I just really want to know if there is a way I can fix this without taking the tranny back out... (hard to find help)
here are some pics of the fork knocked out then when I have it locked onto the bearing... even though its barely on there...
I still think the bearin isnt lined up right.... you know how the spec bearings are kinda squarish?? well I think thats what turned a bit and the fork cant get on all the way...
I was right on the problem... backed the tranny out quarter inch took a screw driver and turned the bearin then put the fork on... went all the way on and havent had a problem since
