shifter sticks or doesn't engage
Old 11-14-2006, 08:08 PM
cbrakillr's Avatar
Default shifter sticks or doesn't engage
when I pull at higher rpm's say 3500 to 6500rpm's 3rd ,4th gears I either can't get it out of gear or get it into gear. I have a stock t-56 but i have a more powerful engine Cam heads exhaust. Anyways i'm not a transmission guy and don't know what the problem is. It works fine when not being driven hard. Any help will be great thanks.
2001 SS Camaro
speedtek f1 cam, granatelli maf, comp springs pushrods rockers, pacesetter lt's slp loudmouth, full hotchkis suspension,port polished heads and tb, 3.73's ring pinion stock rearend(waiting to blow it up) 401.3rwhp 438lbs torque speedtek tuned
Old 11-27-2006, 10:46 PM
SpdFrk1990's Avatar
Just from reading alot of post have you tried the drill mod and how does your fluid look? I will be doing the drill mod soon and flushing my fluid altho mine isnt that bad just pretty notchy more then it should be I think.
