Ls6 or SPEC stage 1 clutch
I just bought a 2000 camaro ss and the clutch is slipping. I don't really want a high performance clutch but I also don't want a stock clutch. The car is a daily driver but will most likely see a day or two at the track. Both 1/4 mile and autocross. I found two clutches that seemed reasonably priced one being the LS6 clutch kit with flywheel and the other is the SPEC stage one. I was wondering which one you guys think would better fit my needs. I have read a few forums and people with SPEC clutches seem to be having some problems. Should I stay away from this brand?
Stock car = ls-7 or LUCK pro gold clutch. I personally have a Textralia, which would be outrageously expensive for your needs. Luk makes factorry GM clutches, and the ls7 makes more power than you now have. If you are not planning any mods, just get a cheap ls7 or Luk replacement. Heavy pedals and lots of chatter are something you shouldn't have to deal with until well past 500rwhp.
Originally Posted by Kyle9100
If I get the ls6 or ls7 clutch do I have to get the master cylinder, slave cylinder, and throw out bearing to go with it?
Originally Posted by BrandonDrecksage
don't get the ls6. the ls7 is aound the same price
