Car stutters in 1st from a stop?
Old 01-02-2007, 12:36 AM
L67toLS1's Avatar
Default Car stutters in 1st from a stop?
I'm not very good yet with the manual, I've only really driven small trucks with one. The car stutters and tries to stall from a stop, I've tried raising the RPM and slowly letting the clutch out(newbie start) and the car still stutters and chatters until it starts rolling a few mph. The car runs great after it starts rolling and has no problems in 2nd-6th gear. I know this probably has some maybe even all to do with my poor driving, but was wondering if my clutch/flywheel might need to be replaced.
Thanks,
James
Old 01-02-2007, 12:38 AM
Revelation Z28's Avatar
flywheel may be warped. or bad clutch.
Old 01-02-2007, 11:49 AM
L67toLS1's Avatar
bump for more help
Old 01-02-2007, 11:53 AM
bastien's Avatar
get your flywheel resurfaced.. I had the same problem.
Old 01-05-2007, 07:08 PM
L67toLS1's Avatar
Bump for more help....
Further description...
In order to keep it from chattering/stuttering and stalling, I must feather the clutch very very slowly the last little bit coming up, without giving gas, once it starts rolling about 2mph its fine. Any gas/not feathering - stutter/chatter/stall.
I'm ready to order the LS7 Clutchkit, but I need to know if there is anything else wrong and I dont want to replace parts I don't need without replacing the problem, will the clutch kit fix it? I need the clutch kit + pilot bearing + slave cylinder correct?
Thanks guys.
James
Old 01-06-2007, 01:37 AM
L67toLS1's Avatar
Just ordered LS7clutchkit from Fred Beans, lets hope this helps the problem.
James
