Help. Clutch won't disengage.
Old 01-04-2007, 09:45 PM
NTMID8R's Avatar
Unhappy Help. Clutch won't disengage.
2000 ls1.Clutch won't disengage.Can't shift into any gear with engine running.Pedal feels normal.Fluid was slightly low and was dark colored(heat).Bled slave till i got clear fluid.Still have good pedal but still won't disengage.Slave was replaced about 6 months ago.No sign of leakage anywhere. Never lost pedal or anything, just quit disengaging.Any ideas?
Old 01-06-2007, 07:44 AM
NTMID8R's Avatar
I was wondering if clutch could be worn to the point where pedal just won't disengage?Or could the master be bad, but work good enough to feel like I have good pedal, but not enough to disengage clutch?Thought about replacing master, but it seems to pump up good and shows no sign of leaking.Confused. Any help appreciated.
Old 01-06-2007, 10:27 AM
jam01's Avatar
this sounds like the problem i had. i ended up having to replace the clutch and flywheel along with the master.
Old 01-13-2007, 03:52 PM
NTMID8R's Avatar
Thanks
