Aftermarket Slave/Master Cylinder?
Aftermarket Slave/Master Cylinder? Ls7 guys come in!
I am about to try fix my ls7 clutch/hydraulic issue. It works fine under normal driving, but if i get on it from a stop the clutch will not come back up on its own i need to pull it up with my foot. I am assuming its a hydraulic problem. Any suggestions as to what i can replace? And if i need to replace the slave and master what do u recommend purchasing??
I believe i have the upgraded 01-02 (master?).
Thanks in advance.
Thanks in advance.
you, me, and many other people on this board have that same problem. i still havent fixed mine. open your master resivor and take the black boot out. be careful not to drip the fluid on the paint of your car. if their is black **** on the bottom of your resivor your master is the problem. there is a black rubber piece that moves back and forth and pushes the fluid to your slave, which then pushes your clutch in. that black piece is worn and is coming apart and pieces of it are coming up into your resivor. hope that helped.
-Mike
-Mike
ya man thanks for your advice, if i figure it out ill definately share it with others. the ls7 clutch should be perfect for my power. i will look at that piece to start, thanks
Any one else have any ideas, yes yes my fluid does get black eventually and i will cover the line but i dont think thats the problem i have changed the fluid once.
