yoke T56
yoke T56
is the yoke from the driveshaft from a T56 the same as a th350 or th400
or th700 ??
as i don't have a driveshaft for my T56 project and the 350's and 400's are easy available
thanks, JeeJee
or th700 ??
thanks, JeeJee
They can be. The key factors are tooth count and wall thickness. Some applications( HD/ Truck) use a thick-wall yoke and , although the spline matches, will not fit the rear bushing.
so you are saying that all th350 and th400 ykoes will fit the gearbox but might not fit the rearaxle ?
i'll have to make a special driveshaft anyway, so it only matters that it will fit the T56 and not the rearaxle....
No, what I said is there are different yokes to match the different applications. The Fcar uses a 27T thin -wall yoke. Some 350 and 400 applications use the same yoke. There are 27T thick-wall yokes and 32T spline thin & thick wall yokes as well. You will have to match the correct yoke to your trans.
