Need Help Quick!!! Drill Mod
Old 03-06-2007, 03:51 PM
timothy_5326's Avatar
Default Need Help Quick!!! Drill Mod
i know its been over a million times, but i cant seem to locate. can someone give me a link to get directions for the drill mod. i gotta change my clutch master tomorrow, and it would be a good time to look into it. THANKS!!!
oh yeah, any tips on clutch master installation would be wonderful....this is my first time workin on one of these ....i have an 11 second IROC, but its all carb, no electronics(except the MSD), and its a th350... i am slightly mechanically inclined. i also saw where its better with two people, so i got my brother comin over to help, and he is slightly mechanically inclined also......thanks again
1987 IROC- mid 11 second street car, 3.42 gears, 350
2000 SS- centerforce clutch, 02' slave cylinder...real pain in my a$$ right now..
Old 03-06-2007, 04:17 PM
....something else.....i hope its the clutch master, i had the slave installed, bled out fine. car drove fine for about 2 weeks. now when i press the clutch and put it in gear, after about 3 seconds it will take off without moving my foot...like its losing pressure. that sound like a master? i went back and re-bled it myself, and it has no air.
Old 03-06-2007, 04:38 PM
brad8266's Avatar
For the drill mod you just need to pop the master hose out of the slave and disconnect the master from the clutch pedal. Its pretty easy to do.
http://www.installuniversity.com/ins...sity/index.htm
Old 03-07-2007, 11:50 AM
as35thss's Avatar
http://chevyhiperformance.com/howto/39021/. See if this helps you.
