getting a clutch what else
Old 03-08-2007, 11:13 AM
LILWS6's Avatar
Default getting a clutch what else
Ok so i have 60,000 miles on my car and i'm getting an ls7 clutch kit with ls2 flywheel. I want to know what else i should get with it do i need bolts bearings what else? i going to have a shop install this because i don't have the time and tools to putts with this. should i also have the drill mod done at the same time?
Old 03-08-2007, 11:14 AM
brad8266's Avatar
new slave and master cylinders cant hurt.
Old 03-08-2007, 12:14 PM
JakeY2KZ's Avatar
Add a pilot bearing in there as well.
Old 03-08-2007, 10:46 PM
LILWS6's Avatar
what about a throw out bearing? and why would i need a new master and slave? the cars an 01?
Old 03-08-2007, 11:08 PM
Y2K SS's Avatar
slave is basically your throw out bearing. I wouldn't worry about the master unless its giving you problems.
Old 03-09-2007, 12:55 AM
Blk97WS6's Avatar
The new slave will come with a new T/O bearing. And I agree, dont replace the master unless its giving you problems. Its no big deal if you need to replace it further down the road because it doesnt require dropping the trans.
