Does your master cyl. leak air and cause a bad pedal???
Old 03-14-2007, 04:43 PM
dalejr8ls1's Avatar
Default Does your master cyl. leak air and cause a bad pedal???
I have a Mcleod master practically brand new with all new lines, new slave, and a Mcleod single disk clutch. I have bled and bled the propper way and I still get a soft clutch...but after driving for 8 min's or so, just like that it firms up and is engaging right at the top of the pedal stroke and works perfectly.
Leads me to believe there is air in the lines. So I hooked up a vacum to the top and after a little while small bubbles started to come up...they dont stop.
I have had about all I could take with this Mcleod master, should I try something or just go for a Ram Adj. Master?
Any advice much appreciated
