Clutch Chirp
Clutch Chirp
I have had my SPEC 3 in for about four months now. It has about 7K miles on it. Recently I have been having a chirp when I shift aggressively. It doesn't matter if I am shifting up or down. It happens when I disengage the clutch. If it weren't an almost new clutch, I wouldn't be so worried about it. Give me some ideas. When I did the install, I flushed the entire system and put brand new fluid in it. I put the spacer in, but I have had no issue with the clutch engaging, or disengaging. The clutch engages and disengages at about half travel of the pedal. Also, I have had no problem with the clutch slipping. The most common occurance (sp?) is when I shift up, or down into third. Let me know what you guys think.
Thanks,
J.R.
Thanks,
J.R.
