Master Cylinder question
Im going to be doing a a4 to t56 conversion in the upcoming months. Im looking at getting a Textralia clutch package from somewhere. Now my question is, should i go with a factory GM master cylinder setup or go with an aftermarket one like a Mcleod for example. Thanks
A stock GM master will work with the TEX clutch, although i always suggest an adjustable. Supposedly the TEX clutch was desigtned around a stock master cylinder. Be sure to get a new slave too.
