Spec slave cylinder shim
Hello,
I'm replacing my spec 1 with another spec 1. I replaced the slave last month and don't remember a shim, however it was on the car for 50,000 miles so it might have just been stuck to the old slave.
Put it back together and have had a plether of issues. Now i'm putting in a new spec 1 and new flywheel.
Problem is I'm not sure if this green peice is just a tranny seal or an old way of shimming instead of the metal plate. Hopefully someone can give me a quick answer
Here is the tranny with the green thing
Here is the shim that came with the new clutch
