grinding into 3rd gear
Old 04-28-2007, 05:53 PM
F-bodyworks's Avatar
Default grinding into 3rd gear
I have a 2000 Z28 six speed. I have noticed that at low RMPs and very high RPMs when i attempt to shift to third gear it grinds and does not allow me to shift. It has also done it once in fourth gear. I pretty much have just stopped using third gear untill i figure it out. I have had no problems from any other gear at any other rpm. Any help you can give would be greatly appreciated.
Old 04-28-2007, 07:37 PM
kookamunga's Avatar
shifter bushing?
Old 04-28-2007, 09:17 PM
Mike44138's Avatar
Could be the bushing but more than likely a bent 3/4 shift fork. Don't use 3 or 4 until you get it looked at, you'll just end up trashing the gears and making the repair a lot more expensive. Do a search here, you'll get the details on the aluminum 3/4 shift fork issue.
Old 04-28-2007, 10:01 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I am willing to bet money on it being a bent shift fork. Chances are you are going to be replacing synchros and blockers when it gets take apart.
Boo"SS"t's Avatar
Sounds like a worn 3-4 synchronizer, they're normally the first one that gives due to speedshifting/powershifting and it may eventually start popping out of gear if you don't have it all the way in the gate.
Old 04-30-2007, 04:27 PM
does anyone know about how much that would cost to fix? you have to pull the whole tranny right?
Second question; anyone know a good tranny shop in Charleston, S.C?
Old 04-30-2007, 06:20 PM
Mike44138's Avatar
Yep trans has to be pulled and torn apart. The fork will probably run you around $50.00 and you can get a synchro rebuild kit which will include blockers, keys, and other misc. stuff for around $250. I would rebuild all the synchros if you're gonna bother to pull the thing apart. Hopefully you haven't done damage to the 3rd or 4th gear and they wont need to be replaced. Check with www.sixspeedsinc.com (sponsor with great customer service) or www.ddperformance.com. You'd have to call on the labor side of stuff.
BTW, you're using a stock shifter, right?
Old 05-01-2007, 01:09 PM
No the shifter is after market. A lous short stick i belive. It's been in there for about a year. Why would that cause the problem i'm having?
Old 05-01-2007, 05:00 PM
Mike44138's Avatar
Does it have adjustable stops? If so make sure they're set right.
Quick Reply: grinding into 3rd gear
