Mechanical Speedo adaptor?
I have installed a T56 6spd in my 1967 camaro but the speedo is electronic. I have been looking into purchasing a mechanical speedo adaptor from the electronic map sensor to the 1967 mechanical speedo cable. Does anyone have any experience with this?
wrencher
There are starting to be quite a few out there now. Some are expensive though
I know they will start becoming common & cheap, these are becoming a common swap item. Auto meter makes speedos that accept a VSS signal also.
http://www.abbott-tach.com/cablex.htm
www.shift works.com tailhousing
http://www.5speedtransmissions.com/t56_early_gm.html
