What clutch holds 1200rwhp in a C5?
the clutch pacs in a TH-400.
Nothing is really gonna hold 1200 on the street too well, unless you baby it around.
SPEC 5, Textrilla may work but I wouldn't trust a clutch at that power level for very long.
I believe the McLeod twin disk can supposedly handle north of 1200 hp, according to them. The new Tex twin disk might too. No experience with either but will soon!!
6600 rpm clutch dump of death Administrator
Torque, not HP is what you measure a clutch's capacity in.
Now, with all that being said...
I was recently in Australia and saw a car that has a Textralia Triple in it that has been holding ~1400RWP on a Dyno Dynamics load dyno. The clutch has been in the car for quite some time. The DD Dyno read about 15-20% lower than a Dynojet. So, that would equate to about ~1600 RWHP on a DynoJet (roughly). Its not advertised to hold 1600RWHP, but I'm just letting you know what I saw when I was there.
The real issue you have is that being as its in a C5, driveline components will most likely give before you reach any clutches capacity for torque holding.
