Trans stuck in 3rd
Trans stuck in 3rd
I wanset racing or anything just normal cruise and my 3rd gear just stuck.
What do guys think I was having problem with clutch when I hit it peddel stuck on the floor.
Btw I just recived SPEC CLUTCH ,01 Slave and Ram master cylinder.
So what to do?
Thanks in advance.
So what to do?
Thanks in advance.
wrencher
Well if you need to put the clutch in, freshen the trans up while it is out.
The poor clutch releasing/sticking took its toll on the trans. Time to upgrade.
Like calhoon says iron 3/4 fork ,& anything else worn.
Might be wise to upgrade 3/4 billet sliders & bronze shift fork pads.
Might want to do the blocker rings as well, so your basically looking at a trans overhaul.
My advise would be to do it up right while your in there.
