Vibration from alluminum flywheel?
I just got my car back together from doing a complete rebuild for my t56. I decided to install a Fidanza alluminum flywheel and new ls6 clutch while the tranny was out. Now it seems that the engine is not as smooth as before with the stock setup. I was just wondering if this is normal.
the fidanza is 1/2 the weight of the stocker. that is alot of mass to remove. the mass helps absorb vibration.
i noticed the exact same thing on my car when i put the fidanza and SPEC 4 in. i figured it was due to the fact that i have poly motor, trans and suspension bushings, so i was feeling it more.
