issues with my 02ta
Old 05-19-2007, 01:41 PM
96ta's Avatar
Default issues with my 02ta
I was at the track last weekend and i was making my run well after passing the quarter mile marker id take the car out of gear and brake but when i would bring the clutch back up to disengage it, it felt like it was catching halfway and not releasing. if i pumped the clutch a few times it would go away. ive been told that it could be my throw out bearing or pilot bearing. i was thinking more along the lines of a bad pressure plate. any ideas as to what it is. btw the car is not leaking any fluids.
Old 05-19-2007, 07:11 PM
wrencher
wrencher's Avatar
If you have to pump the pedal up thats the indicator of hydraulic issues.
might need to flush the fluid/ drill mod I'd start there. Has any clutch work been done ever?
Old 05-19-2007, 11:43 PM
96ta's Avatar
well i cant be certain but i bought the car earlier this year and it only had 8600 miles on it so i dont really see very probable. is there a link to the drill mod thread/directions?
Old 05-20-2007, 10:45 AM
wrencher
wrencher's Avatar
At the top of manual trans section in the sticky'd threads.
https://ls1tech.com/forums/manual-transmission/510788-manual-transmission-faq-look-here-first.html
Old 05-21-2007, 07:15 AM
96ta's Avatar
thanks
