How much for clutch and flywheel install?
Need input quick. The car is in the air having the master and slave cylinders done. The tech says he noted hot spots on one side of the fly wheel that may indicate something is misaligned. The wear on the clutch itself is only about 40%. He recommends replacing the clutch and flywheel since the tranny is already torn down. How much should they charge since the transmission is already partly disassembled?
Thanks,
Thanks,
Originally Posted by teke184
i would think an hour's labor at most.
all it takes is a few minutes to unbolt and rebolt the flywheel and PP.
