Borg Warner T56 questions
Okies..
Just bought myself a T56 gearbox.. yet when it arrived it has Borg Warner embossed on it.
What i want to know is.. Is the Borg Warner T56 as strong as the Tremec? Are they virtually identical?
Can anyone tell me any more information on the gearbox i've written down all the info off it i could see.
on teh casing itself
BW
13-86-066-904
on a tag on the casing
92055432 J2392
1386 022 E 01062
any information would be cool as i outlayed AU$2800 for the gearbox and last thing i want is to find out its an old T5 or some ****.
BW
13-86-066-904
92055432 J2392
1386 022 E 01062
Re: Borg Warner T56 questions
It's definitely a T56.
ratios are
2.66
1.78
1.3
1.00
0.74
0.5
2.9 reverse
tq rating is 350lbs-ft / 474 Newton-metres (curious; all the other 2.66/.50 boxes are 450lb-ft it seems )
The gross vehicle weight rating is 3400lbs/1542kg
It weighs 138lbs/62.4kg
There is no meaningful strength difference between a 97 Z28 and 99 Z28 trans., though I believe the 97 was produced by B/W and the 99 by Tremec. However, I don't know what application your trans. is; did you buy it in your country or ship it over?
Matthew
ratios are
2.66
1.78
1.3
1.00
0.74
0.5
2.9 reverse
Matthew
