problem with 5th gear
Old 05-30-2007, 09:46 PM
styoung's Avatar
Default problem with 5th gear
car wont go into 5th all the time, sometimes it will others it grinds and wont go in, does anyone know what could be wrong, thanks
Old 05-31-2007, 01:08 PM
Hackscamaro's Avatar
mine would do the exact same thing. i had synchronizers going out. i also had a bent shift fork and the main shaft was stripped a little. i would say it is the sychros though.
Old 05-31-2007, 01:15 PM
Banging some gears
greyghost4x4's Avatar
mine did the same... mechanic said that the pin cam out of the 5-6 slider... whatever that means
