RAM Adjustable Master Cylinder help
Old 06-14-2007, 01:38 AM
tech2's Avatar
Default RAM Adjustable Master Cylinder help
im not terribly technical so please dont jump all over me. i did a search and this is what i got.
There seems to have been a slight problem with the LS1TECH database.
Please try again by pressing the refresh button in your browser.
An E-Mail has been dispatched to our Technical Staff, who you can also contact if the problem persists.
We apologize for any inconvenience.
i have about 150 miles on my car since the new clutch and it seems like the catch point is much higher than it was when i left with the car. any ideas of why it would change? ive been taking my time since the new clutch was installed. any help would be appreciated. i have a hellion cam and if i only used the clutch to take off it almost stalls so i have to give it alittle gas to get it moving sometimes. where i live i face about 5-6 hills on my commute to work. if i only used the clutch to take off i would never make it to work, definatly would stall. thanks again
Old 06-14-2007, 07:56 AM
wrencher
wrencher's Avatar
You could have it over adjusted. The pedal should have just a tad of play in it when depressed from the rest position.
Old 06-14-2007, 08:03 AM
ghettocruiser's Avatar
I can never figure out how to "properly" adjust my RAM either. Like to get a good starting point.
This time, Im using a stock master, with the RAM adjustable rod installed...so basically a RAM. I tried to make it as close to the total lenth of the stocker just for a start. But I dont know how to tell if the adjustment is off.
J.
Old 06-14-2007, 08:17 AM
tech2's Avatar
im taking back to new era performance today, they installed it. i will report when i return.
