Trans Or Clutch Problem????
Went to the track and had problems.At high rpm(6600)the trans would not go into gear,it did not grind just didn't go in 3rd or 4th and somtimes 2nd.Well after a few passes i just got pissed and jammed it into gear still no grinding just took more force than at low rpm. on one pass it jumped out of fourth.And at the end of the night the cluch pedal would only come about half way up. The clutch was slipping pretty bad(stock clutch 114,xxx miles) So what do you guys think ? what's the damage?
wrencher
Read the Manual trans FAQ top of this section for one.
But sounds like you need to spend lots of $$ soon to make all those woes go away.
Clutch, hydraulic's possible trans rebuild if it keeps popping out of gear etc.
