B & M Ripper install
I'm installing the ripper in my 02 WS6. I have never done this before and the shifter has no directions with it. Are there any adjustments or anything special I need to watch out for?
http://www.installuniversity.com/ins...sity/index.htm Click on Install Documents on the left side, scroll to the bottom and click on Shifter Install. Hope that helps.
Yeah...watch out for the slotted mounting holes. If the shifter is new, it will have all the washers to adjust the shifters mount position. If its used, I hope you got atleast SOME of those washers...because the holes are slotted... Then again if its new, you should have instructions. You can also download the instructions from B&M's website.
Here..did the leg work for ya...
http://www.bmracing.com/media/products/pdf/31.pdf
Justin
Justin
