A4 to M6
Old 07-09-2007, 12:12 PM
formulamd's Avatar
Default A4 to M6
Hi,
I couldn't find what I wanted in the search so, Im in the process of doing a A4 to m6 swap in my 2001 formula. My question was if i get all the wiring to the computer correct could the car be driven for ~10 miles. to get tuned or am I needing to flatbed the car to get the car over there?
regards,
Mike
Old 07-10-2007, 09:57 PM
formulamd's Avatar
Anybody? Or did I post this in the wrong section?
Old 07-24-2007, 11:01 PM
AGray89's Avatar
Alright, I have no idea, but im just going to try and help... I have never done this but me and my friend are about to do a a4 to m5 swap on his firebird and I was reading up alot about it and I did read that you can drive the car after getting everything together, but you wont want to for long before you reprogram the computer... I dont know if that helps, but maybe this will draw some more attention for ya so someone else will help...
Old 07-24-2007, 11:14 PM
6-Speed Terror's Avatar
well your speedo will be off a bit. the pcm will be tring to shift but there is no gears for it to change. you will most likely get a ses light cuz it will command 2nd gear or first but nothing. i say go for it nothing will happen to you engine if that is what you are worried about
Old 07-25-2007, 12:04 AM
Blue 98 Ram Air's Avatar
yeah u should be ok but might want to look into a flatbed
Old 07-25-2007, 03:23 PM
TLUZLS1's Avatar
I think I would play it safe and get a flatbed, but Im no expert...
Old 07-25-2007, 10:58 PM
formulamd's Avatar
Great thanks guys,
The only thing i was worring about would be if my motor gets messed up.
Quick Reply: A4 to M6
