notchy hurst shifter...
Old 07-14-2007, 08:23 PM
TXFORMULA's Avatar
Default notchy hurst shifter...
i have a hurst short throw shifter which i installed myself. i torqued everything to proper specs and used gasket maker and everything. now ive driven it a few hundred miles and there seems to be a notch in between 1st & 2nd. it will go into 1st but i have to move it around a little to get it there. then when you shift to second its like theres something there... i have a brand new clutch. could the stops need adjusting? it makes me worried im going to miss second. any suggestions? thanks again guys, so far you all have been helpful with my other Qs
