clutch issue
Old 07-16-2007, 09:32 PM
SwEeTWs6's Avatar
Default clutch issue
Hey guys I am having a problem with something in the clutch system. On ocassion it use to grind 2nd or 3rd when going into gear. Now with clutch fully down it has gotten worse. I was leaning towards the slave cylinder but want some opinions first. The clutch is still stock and no drill mod has been made. Let me know what you think thanks....
Old 07-16-2007, 09:55 PM
JonB's Avatar
Is this happening at WOT or just normal driving. Either way you may want to try bleeding the system before you do anything, then try the drill mod. Also be sure your tranny fluid is full.
