LS7 clutch unstsll question
Old 07-21-2007, 04:26 PM
98TA_vert's Avatar
Default LS7 clutch unstsll question
I ordered the LS7 clutch kit from scoggin and i wanted to know can i use the flywheel and pressure plate bolts from the LS1 clutch or are they different? I'm ASSuming that they will work being new ones are included in the kit i just want to double check.
Old 07-21-2007, 05:55 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You can reuse your stock hardware
