Transmission Problem
I have just installed: Spec Stage 3 + PRESSURE PLATE) BILLET ALUMINUM
Aluminum Flywheel McLeod master cylinder
But I did not install GM Slave Cylinder 2001
I have to like keep pumping the clutch and if I floor it in second not even in first the clutch is sticking do you think it’s because I did not put GM Slave Cylinder 2001
You have air in the system as was stated. "Mityvac" my friend, its a tool to suck it out from the top, you can even do it alone. Then adjust the master. You can also just drill your slave later, but you probably know that old trick its a quick fix.
LS1Tech Administrator
Received 1,492 Likes
Moving to Manual Trans section....
