spec 2/ hydraulic problems
my car is in the shop getting this new setup put in. from what the shop told me the car has to be off to go into first then when turned on engages imediately off the floor. also won't go into any gears using the clutch once moving. the shim is in place on the slave and the guy says he's tried gravity bleeding, vacume bleeding and some other kind of bleeding. from reading around in this section and talking to a tech guy at spec i would swear it's not bled properly. if anyone has any other input i'd greatly appreciate it.
