welding a broken T56 housing
Old 08-30-2007, 12:40 PM
moserman's Avatar
Default welding a broken T56 housing
has anyone in here had a T56 that needed to get the housing welded? If so, how did the shop go about doing it? i obtained a surface crack just big enough to leak out all of my trans fluid. i want to get it bevel welded but i realize welding aluminum is not the easiest, anyone have any tips for me?
Old 09-12-2007, 11:38 AM
chromeplated500's Avatar
Well i had my bellhousing welded and my oil pan welded. I knew the guy and he does one hell of a job. bevel welding I would suggest bevel welding it, two or three passes on it. But the biggest thing i would stress is getting somebody good, its not super duper hard, but I would imagine some **** could get screwed up.
Old 09-12-2007, 12:56 PM
stealth71's Avatar
Makes me wonder why it cracked? Any other problems lurking?
Old 09-12-2007, 04:06 PM
thesource's Avatar
Depending on why it cracked in the first place , I don't see any issues with getting it rewelded .
Old 09-13-2007, 12:24 PM
toplessHO's Avatar
make sure the weld area is cleaned real good as its porous and since a leak
has passed fluid thru it will soak up fluid.
Also drill a hole on each end of crack.
Old 09-13-2007, 12:28 PM
Ping King's Avatar
tailshaft housing?
Old 09-24-2007, 11:25 AM
moserman's Avatar
yeah its on the underside of the tailshaft housing, but the bellhousing broke because the bolts came loose and the torque forced a crack in it, but the other crack was from bottoming out on a manhole cover.
Quick Reply: welding a broken T56 housing
