Wierd sqeuaking noise after Clutch install
Ok this is going to sound odd. I just had a clutch installed, a Textralia and it feels great, but as soon as I took the car home there is a very annoying squeaking noise I cannot figure out where it is coming from. It definitely was not there before the clutch was put in, so I am figuring they left something loose.
Description: It comes and goes, sounds like a loose clamp, bracket, it is not from the suspension, it sometimes squeaks when I idle the car after driving it, it sometimes makes the noise when I hit a bump and sometimes it doesnt happen. I checked the brakcets by the tailpipes, lubed the mounts, still does it. I checked the sway bar, shocks, springs, panhard rod, exhaust clamps, all seem very tight.
It sounds like it comes from the hatch or the rear of the car and is seems like the passenger side. But it is very difficult to pinpoint where it is coming from.
I am just wondering what from a clutch install i should check to see where this noise is coming from.
Thanks,
Sam
Thanks,
Sam
