need help with ram adjust. master cylinder
I bought and installed a ram master cylinder but on the clutch pedal i can't get the stock clip back in the groove that retains the plunger...any ideas...thoughts or help please....
and how long does it take to bleed one of these if it was not pree bled?
Restricted User
I bench bled mine, took 10 -15 minutes to make sure all of the air was out. Also I ground the side a little to make it thinner and the clip went right on after that. The heim joint is a hair too wide.
