bleeding clutch questions
Old 09-17-2007, 07:49 PM
WS SIKZ's Avatar
Default bleeding clutch questions
ok f#$k it where do you cut a hole in the floor to get to the bleeder 1, and 2, when you bleed it does fluid leak back into the hole where the bleeder is can damage ne thing?
Old 09-17-2007, 07:55 PM
brad8266's Avatar
1. Directly to the right of the gas pedal through the tunnel that the trans sits at.
2. Fluid leaks back but it goes out the hole in the bellhousing, you dont have to worry about it.
Old 09-18-2007, 02:28 AM
z28fury's Avatar
Mity Vac.
Old 09-18-2007, 08:32 AM
brad8266's Avatar
What does a mity vac have anything to do with what he asked?
